Date/Time: Fri, 24 Jan 2025 14:42:09 +0000
Odd behaviour from zigzag based on last, on range charts
View Count: 714
[2019-01-24 19:34:40]
User339031 - Posts: 5
I'm running zigzag on an 8 range chart of ES, based on last for input high and input low, calc mode 3, and reversal 1.5, ie 6 ticks, and I'm getting a different plot after recalculating.
To illustrate, I ran this morning's session through the simulator, took a screenshot, then recalculated and took another screenshot. Please see attached.
I'm also attaching a screenshot of the zigzag settings.
The result after recalculating matches a similar chart in another trading package.
Any ideas?
Phil
http://www.sierrachart.com/image.php?Image=1548358007323.png
http://www.sierrachart.com/image.php?Image=1548358139272.png
imagezigzag settings.PNG / V - Attached On 2019-01-24 19:30:23 UTC - Size: 49.25 KB - 264 views
[2019-01-24 21:02:39]
This behavior is already documented:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#Inputs_InputDataForHigh
Setting this input to Yes should help with this:
Zig Zag: Calculate New Values on Bar Close
Date Time Of Last Edit: 2019-01-24 21:03:08
[2019-01-24 21:38:21]
Thank you!
