Date/Time: Fri, 24 Jan 2025 14:31:53 +0000
VBP on DOM - Diffrent Intervals
View Count: 724
[2019-01-24 15:07:38] |
User993067 - Posts: 156 |
Chart interval on DOM is set 610 trades...VBP is 10 bars...I would like to add 10 bars of 5 minute interval side by side to the 610 trades/ticks...Whenever I attempt to change the settings the additional VBP either disappears entirely or makes no change at all...Is what I am seeking possible
Capture2.PNG / V - Attached On 2019-01-24 15:03:12 UTC - Size: 94.61 KB - 309 views |
[2019-01-24 19:44:17] |
No, this is not possible. You need to use a separate standard chart for this.
