Date/Time: Fri, 24 Jan 2025 14:33:56 +0000
Natural Gas (NG) Contract Automatic Rollover
View Count: 1031
[2019-01-24 11:55:31] |
User94606 - Posts: 327 |
I have NG set to the following in the Chart Settings window: 1. Checked enabled in Main Settings: "Automatically Rollover Futures Symbol" 2. Advanced Settings: Continuous Contract: "Continuous Futures Contract - Volume Based Rollover" NG was currently on Feb 2019 and did not automatically rollover to Mar 2019. Any ideas on why? |
NG Rollover.jpg / V - Attached On 2019-01-24 11:55:22 UTC - Size: 258.18 KB - 364 views |
[2019-01-24 15:51:37] |
John - SC Support - Posts: 37448 |
Refer to the documentation for "Automatically Rollover Futures Symbol": Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Note the connection between this setting and the Continuous Contract setting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
