Date/Time: Fri, 24 Jan 2025 14:48:13 +0000
How to Copy Global Graphics Settings
View Count: 3580
[2019-01-23 22:51:52] |
User94606 - Posts: 327 |
I have a global settings saved in the primary instance of Sierra Chart. How do I copy the saved "Graphics Setting - Global settings" from instance #1 to Sierra Chart instance #2?
[2019-01-24 15:22:19] |
John - SC Support - Posts: 37448 |
You just need to copy the Sierra3.cfg file from the main instance folder to the sub-instance folder. You will find the information on copying files to another instance here (just think of the sub-instance as another installation of Sierra Chart): Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Just make sure that neither instance of Sierra Chart is running when you copy the configuration file. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-24 19:32:57
