Date/Time: Fri, 24 Jan 2025 14:45:58 +0000
[User Discussion] - OPTIONS QUESTION FOR SIERRA CHARTS
View Count: 955
[2019-01-23 16:43:36] |
User594596 - Posts: 3 |
HI, I WANTED TO KNOW HOW CAN I SEE THE PREMIUM REQUIRED TO PURCHASE AN OPTION FOR TREASURY FUTURES, ALL I SEE IS TICK VALUES. i AM ASKING SINCE I PAY THE PREMIUM TO BE ABLE TO BUY FUTURES, FOR WHICH I WILL NEED A MARGIN OF X. SO I WANT TO KNOW IF MARGIN FOR 2 CONTRACTS IS 2000 AND I HAVE 3000, HOW DO I KNOW THE DOLLAR VALUE OF PREMIUM I WILL PAY UPFRONT ? |
[2019-01-27 16:29:39] |
CAN SOMEONE HELP ME WITH THE ABOVE ? AM I NOT ASKING AT THE RIGHT PLACE ?
[2019-01-27 19:38:18] |
This is not functionality that Sierra Chart provides.
[2019-01-27 19:43:59] |
hi, then how do i know the margin needed to maintain a purchase for a contract ? if outright is 500usd and i have 1000usd will my transaction be accepted ? |
[2019-01-27 22:09:40] |
Merlin - Posts: 83 |
This is really a question for your broker. It's not a Sierra issue - whatever the answer is, it will be the same no matter what software you're using to chart the option. But it may be different for different brokers - brokers have some leeway in setting their margin policies, as long as they meet CME's minimums. This gives some basic information, seems rather complex: https://www.cmegroup.com/education/articles-and-reports/a-primer-on-margining-styles-for-options.html One more reason I'm not trading futures options. :-) |
