Date/Time: Fri, 24 Jan 2025 12:59:32 +0000
[Programming Help] - text color
View Count: 617
[2019-01-23 15:28:05]
markuz - Posts: 90
Can you create a text script that adjusts to a second variable?
For example, coloring the text study vs. the close will some me current direction vs the script.
In use the Study Summary, and having a single script versus creating multiple Text study script is the request in context. Here, the labels would be green or red, instead of the static yellow.
imagesierra_text_example.png / V - Attached On 2019-01-23 15:27:56 UTC - Size: 3.57 KB - 251 views
