Date/Time: Fri, 24 Jan 2025 13:00:43 +0000
Heikin Ashi
View Count: 2634
[2019-01-23 01:31:29] |
User394215 - Posts: 2 |
Hello, Heikin-Ashi and Heiken-Ashi are the same candles? I activated Heikin-Ashi in Studies Windows, then I went to "Chart Settings" and on "Graph Draw Type" I selected "Blank". Is this the only I must be do to operate Heiken-Ashi in real? Date Time Of Last Edit: 2019-01-23 03:29:50
[2019-01-23 06:59:37] |
What instead you will want to do is enable Display as Main Price Graph for the Heiken-Ash study: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-23 07:00:12
