Date/Time: Fri, 24 Jan 2025 13:00:25 +0000
Viewable Stats by Note Field
View Count: 624
[2019-01-22 20:49:42] |
User993067 - Posts: 156 |
Is it possible to enable a summary statistical view for each trade window configuration files (exit strategy) in the notes field? Right now each for each the corresponding .twconfig file name is labeled in the notes field, but I cannot analyze or view a summary of the days trades by .twconfig files. This would allow me to see clearly which exit strategy (.twconfig) is working best. Perhaps a drop down list with check marks for each strategy you want to analyze? |
[2019-01-22 20:57:30] |
Yes this is supported through the Trade >>Trade Activity Log, you will see the Notes drop down list at the top right of that window.
[2019-01-23 16:07:20] |
I have two computers for trading...the one with SC is for execution only and the single screen is in portrait mode...for whatever reason the far right of the window is cut off and i can't see those drop down windows for notes currency... when i log into SC on the other charting computer which has 8 screens in landscape mode i see the drop down boxes...but my trades are logged on the other computer..so the data is empty... you have a workaround? |
Attachment Deleted. Capture.PNG / V - Attached On 2019-01-23 16:04:33 UTC - Size: 15.12 KB - 256 views |
