Date/Time: Sun, 24 Nov 2024 15:09:25 +0000
Data feed (Soybeans) problem?
View Count: 1377
[2013-11-11 17:30:35] |
User36492 - Posts: 48 |
Historical(daily,weekly,monthly) charts for soy looked hosed this morning...see attachment
[2013-11-11 17:49:39] |
Go to Global Settings >> Symbol Settings. Press Update From Server. Wait for the button to reenable and then press OK. Go to each Historical chart for that symbol and select Chart >> Chart Settings. Press the Apply Global Symbol Settings button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-11 17:53:53] |
Well, I was trying to avoid that because it wipes out the session times I set for the futures markets I trade. Is there any way to avoid losing custom session settings?
[2013-11-11 18:03:52] |
Ok, I got it... I just had to uncheck the overwrite existing setting box... Sorry
