Date/Time: Fri, 24 Jan 2025 13:14:37 +0000
How to view bar data values on charts?
View Count: 1217
[2019-01-22 14:48:31] |
User462086 - Posts: 196 |
This must be something simple but I haven't been able to find it despite several searches. I'd like the OHLCV (etc) data points to be available at the top of the chart for the bar under the cursor. Currently only the last bar's data is available. Many thanks!! |
[2019-01-22 19:42:44] |
Refer to: Chart Drawing Tools: Chart Values/Crosshair (Chart Values tool) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-22 19:42:53
