Date/Time: Fri, 24 Jan 2025 11:09:10 +0000
lost charts
View Count: 791
[2019-01-22 12:56:36] |
User739935 - Posts: 37 |
some of my charts seem to have disappeared when I start Sierra.It happened yesterday so I created a new chart with all my studies and when I started this morning they were gone once again.Charts for e.g.NQ charts.
[2019-01-22 19:40:24] |
There are backup Chartbook's available: Chartbooks (Workspaces): Accessing a Backup Chartbook File And make sure you have saved the charts as a Chartbook. Here is the complete documentation: Chartbooks (Workspaces) If you save a Chartbook, then it simply should be there when you restart Sierra Chart and should contain the previous charts. This is very basic and reliable. If you have any consistent issue with this, we can look at it with remote assistance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
