Date/Time: Fri, 24 Jan 2025 13:16:40 +0000
User Email: Problem with my SP500 graphs
View Count: 669
[2019-01-22 03:58:09] |
Sierra Chart - Max - Posts: 5779 |
Hello Sierra Chart,
As you can see below I'm having problems with my SP500 Index graphs in 1 Minute, 15 minutes, etc. This graphs do not download properly. Currently I have a simulated account. User 741046. Data/Trade Service Settings. Service: SC Data_All Services Thanks for your help Sierra Chart Support Date Time Of Last Edit: 2019-01-22 03:58:59
[2019-01-22 20:52:37] |
Do not use that symbol. You need to use the symbol ESH19 instead.
