Date/Time: Fri, 24 Jan 2025 13:12:31 +0000
highlight a level not the candle based on condition
View Count: 1109
[2019-01-22 02:29:33] |
User968625 - Posts: 260 |
Hello, Is there a way to highlight a level not the candle when a condition is met. A simple example when the VWAP (dynamic calculation) is equal to Yesterday high (or within a range that is equal ATR). I would like then to highlight the level as a Support or Resistance. I hope that is not custom work and this awesome platform has an easy solution thanks |
[2019-01-22 21:34:24] |
John - SC Support - Posts: 37448 |
The closest that is available is to have a line drawn until by using the Color Bar Based on Alert Condition study. The best setup is to use a Subgraph Draw Style of Dash, and then set the Draw Extension Lines to Color Bar Value to Yes and set the Extension Lines Range as you desire. Refer to the following documentation for the Color Bar Based on Alert Condition Study, you will need the information in the section entitled Drawing Arrows/Text or Other Styles at the High or Low of Bars: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
