Date/Time: Tue, 18 Mar 2025 15:00:36 +0000
Volume Profile - Minimum filter of volume by bar to highlight VPOC & Value Area
View Count: 1874
[2019-01-21 16:45:05]
User333787 - Posts: 3
Is there any way in the Volume Profile or Number Bars of highlighting the VPOC and Value Area of a bar by a minimum volume? So if a bar has 15K of volume or more the Value Area and VPOC will be highlighted and any bars with thing less than 15k no highlights. I tried to use the chart volume filter but that only filters volume by trade.
Thanks!
[2019-01-21 20:14:50]
No, this is not supported.
[2022-09-23 15:01:58]
Sierra_Chart Engineering - Posts: 18817
There is only the Volume Filtering available for the chart itself which also affects the Volume Profiles.
