Date/Time: Fri, 24 Jan 2025 11:21:27 +0000
Free Trial
View Count: 1002
[2019-01-21 10:24:40] |
User875381 - Posts: 1 |
Hello, for the free trial, can I expect taht the link to IB's TWS works and a RT datafeed for Forex pairs. At the moment nothing works. Regards. |
[2019-01-21 15:40:50] |
Sierra Chart - Max - Posts: 5779 |
A. Yes, in a Trial your can connect any supported Data / Trading Service, which includes IB. Refer to the IB setup instructions here: Interactive Brokers Trading Service: Setup Instructions B. Note that all direct Sierra Chart accounts include the "Sierra Chart Real Time and Historical Forex and CFD Data Service", which offers a high quality real-time and historical Forex and CFD data. Sierra Chart Real Time and Historical Forex and CFD Data Service C. Your trial account has not been extended. We see that you have previously used Sierra Chart and have had at least 15 days of trial time. You will need to make a payment for usage time. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support Date Time Of Last Edit: 2019-01-21 15:41:25
[2019-01-21 20:11:33] |
We temporarily extended your trial by 5 days so you can connect to Interactive Brokers and try that connection.
