Date/Time: Fri, 26 Apr 2024 23:54:10 +0000
new manage chart drawings window can't select multiple items
View Count: 1225
[2019-01-21 09:25:19] |
4646ed - Posts: 230 |
the new manage chart drawings window is definitely an improvement but it takes away one of the most useful features: to be able to shift and select multiple drawings and apply universally a simple change like 'lock' or 'unlock'. Until you put that back in I won't be upgrading to the versions that use the new window. It saves me hours in a day. |
[2019-01-21 09:30:51] |
This is supported, you just need to enable the option "Multiple Selection".
[2019-03-16 13:55:26] |
User97684 - Posts: 136 |
Hi, PLease help - how to select all drawings ? It was dead easy before, manythanks |
[2019-03-16 22:22:32] |
To select all of the items, enable the Multiple Selection checkbox at the top of the Manage Chart Drawings window. Select the first item in the list. Scroll to the bottom of the list. Hold the Shift key on the keyboard and select the last item. All items will now be selected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
