Date/Time: Fri, 26 Apr 2024 21:35:16 +0000
Charting/plotting FIB dates on a horirontal axis
View Count: 919
[2019-01-21 08:30:05] |
Ed Meckelborg - Posts: 71 |
Does SC have the capability of marking or indicating Feb dates from an important high or low on into the future. The days that I'd like to see are 1,2,3,5,8,13,21,34,etc, marked on the S.Chart, on the horizontal axis. I know that TradeStation and Thinkorswim [TOS] have that capability. I used Trade Station in the past. If SC does not have that capability, maybe you have a programmer that could add this feature, or direct me to a site that would allow such a download into SC.
[2019-01-21 21:18:36] |
The Time Expansion Drawing tool can do what you are asking for. Refer to the following documentation, particularly the section about Marking Bars Certain Bar Counts Forward: Chart Drawing Tools: Time Expansion Also, take a look at the Time Projection Drawing tool to see if this may be a better fit for what you are looking for: Chart Drawing Tools: Time Projection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-22 21:00:39
