Date/Time: Tue, 23 Apr 2024 22:19:37 +0000
ASX Equities Data - From CQG
View Count: 1380
[2019-01-21 02:31:50] |
User580737 - Posts: 8 |
Hi: CQG provides ASX Equity data live intraday - Non tradeable. I will be using CQG data and trade routing for other exchanges. Is it possible to chart the intraday data for ASX Equity's provided by CQG ? (I asked CQG and they said yes - but would be up to SC / the third party software provider). I have checked other threads and ASX Equity data live is available in SC from IB - but an IB brokerage account is not really a preferance. Thank you |
[2019-01-21 09:27:29] |
Sierra Chart can access all symbols made available from CQG. You just need to manually enter the symbols and make sure your CQG account is authorized for historical data. Refer to: CQG Trading Platform Service: CQG Symbol Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
