Date/Time: Wed, 08 May 2024 02:25:03 +0000
Support for multiple programming languages
View Count: 1230
[2019-01-20 21:19:04] |
stocknerd1 - Posts: 10 |
Hello, I am wondering if it is possible to apply formulas for alert conditions with programming languages such as python or C# for example. If not is this something that may be in the works? Thank you Sierra team |
[2019-01-21 19:15:28] |
You can only use other languages when you are working with the DTC server in the Sierra Chart: Data and Trading Communications (DTC) Protocol Server So you could access the market data and then create alerts in your own way using that language. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
