Date/Time: Thu, 25 Apr 2024 09:35:55 +0000
Window snap back when I try to maximize it by double clicking on top.
View Count: 638
[2019-01-20 09:05:44] |
User541156 - Posts: 67 |
I have hidden the title bar, and am finding that double click on the left over top bar to maximize the chart window has peculiar behavior. About 80% of time it quickly snaps back to previous size after maximizing for just a second. Most of the time, second try works. Is this expected ? I can record the screen to show what is happening if that would be helpful. |
2019-01-20_19-31-38.png / V - Attached On 2019-01-20 09:04:55 UTC - Size: 59.27 KB - 225 views |
[2019-01-21 02:03:00] |
You certainly are going to run into odd behavior when you do things like hiding title bars and trying to maximize the window. The operating system does not handle these things well.
