Date/Time: Fri, 24 Jan 2025 09:58:30 +0000
Chart drawings window crashes SC
View Count: 587
[2019-01-18 16:58:32] |
User403598 - Posts: 15 |
First issue 1) select CB "multiple selection" 2) select few drawings 3) press delete button 4) program crashes The second issue: 1) select the different instrument 2) after deleting a drawing the instrument will be changed to first one The third: 1) select the different instrument 2) select CB "multiple selection" 3) select few drawings 4) press delete 5) only one drawing will be deleted symbols select box is very small just 2 raws Date Time Of Last Edit: 2019-01-18 17:12:28
[2019-01-18 19:26:33] |
We have verified that all of these are resolved. Or just do not exist in the latest prerelease. To update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
