Date/Time: Fri, 24 Jan 2025 09:38:19 +0000
SMS Not Receiving
View Count: 944
[2019-01-18 13:56:14] |
User9415867 - Posts: 38 |
I set up SMS alerts. I addeded my number as +1 xxx xxx xxxx to the global settings - general settings - alerts/general 3 When it crosses the set alert, I hear a ding on my computer but there isn't a text message sent. I added extra credits to my account as well. |
[2019-01-18 17:54:18] |
If you are not getting them, then verify the phone number is correct and it is certainly correct to be using a +1 in front of it. If you still have a problem start an account support ticket and tell us the SMS number you are using: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-18 17:54:31
