Date/Time: Fri, 24 Jan 2025 09:55:50 +0000
cumulative delta
View Count: 704
[2019-01-18 13:47:04] |
Trader&Hunter - Posts: 131 |
I am trying to figure what the digits on the cumulative delta volume mean. I am using a 1000 volume chart on YM and the delta is showing 200. what exactly does that mean?
[2019-01-19 23:54:10] |
If you are referring to the Cumulative Delta Bars-Volume study, this is documented in detail here: Cumulative Delta Bars - Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
