Date/Time: Fri, 24 Jan 2025 14:40:47 +0000
different volume numbers in same chart when duplicated
View Count: 803
[2019-01-18 10:19:09] |
User541842 - Posts: 34 |
hi there, when i duplicate my Chart, the volume numbers in the vBP study are changing at some Pricelevels. effected are also the cumulative delta study and the volume study. how come? |
Private File Private File |
[2019-01-18 10:42:57] |
very dissappointing is a different vproc in the 30 Minute profile
Private File |
[2019-01-18 11:04:53] |
duplicated the Chart again some time later. different volume value area lines study Level -> see volume value area line study high |
Private File |
[2019-01-18 11:17:21] |
closed the platform with save all and opened again. duplicated the Chart and theyre good. the Chart that duplicated Shows now a higher vah from the volume value area lines studey. see screenshot last post |
good after platform close.png / V - Attached On 2019-01-18 11:15:43 UTC - Size: 205.31 KB - 281 views |
[2019-01-18 17:22:26] |
Refer to this section here: Volume By Price Study: Volume Profile Differences There must be some difference between the chart data in the chart or the chart settings or the study settings. It is not within the scope of our support to analyze this. If you do require further help it is chargeable at 55 USD per hour. You also did not post images according to our specifications: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-18 17:23:48
[2019-01-19 11:19:51] |
its a duplicated Chart, so there cannot be any difference. i can make a short Video next week for you. would this help? |
[2019-01-24 22:40:17] |
A video will not help: Support Board Posting Information: Do Not Post Videos Unless Requested! There still can be differences in the case of a duplicated chart and we updated the documentation to consider all possibilities. Go through that first: Volume By Price Study: Volume Profile Differences What can be different is the first Date-Time loaded in the chart because that can change when a chart is duplicated. This is explained more here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-25 05:45:51
