Date/Time: Fri, 24 Jan 2025 09:51:45 +0000
updating without installer
View Count: 898
[2019-01-18 07:44:52] |
User884550 - Posts: 149 |
is it possible to update sierra simply by copying some files into sierrachart folder instead of using executable installer? due to company IT security settings I have to look for IT guy and he has to ask for one-time password to run any .exe |
[2019-01-18 17:43:39] |
You can use the zip installer: https://www.sierrachart.com/index.php?page=doc/SCZipInstallerList.php But it is really not the recommended method and is only for users that understand how to move the files around that they need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-18 18:14:59
