Date/Time: Sat, 01 Feb 2025 12:39:01 +0000
setting background color for DRAWSTYLE_CUSTOM_VALUE_AT_Y
View Count: 973
[2019-01-18 00:03:09] |
Andy Sureway - Posts: 93 |
Hi SC team, For the output subgraphs, It seems that the variables SecondaryColor and SecondaryColorUsed for setting background are not working. The issue was first reported here but lacking of response. How to draw different text on chart by Subgraph function? Thanks! |
[2019-01-18 19:21:48] |
These are not supported with that Draw Style but we will see if we can add support for them without any consequence to existing studies.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-18 19:22:03
[2019-07-17 21:10:52] |
This is now supported.
