Date/Time: Fri, 24 Jan 2025 13:02:06 +0000
Not able to change the line color in Add Addtional Symbol
View Count: 1207
[2019-01-17 23:21:13] |
Tariq - Posts: 16 |
Hi folks, I am creating a chart of Crude oil spreads for a few of the spreads on one chart. I am using Line on close for the symbols. The problem is the colors for all of the lines stays the same. It seems the symbols are copying the main chart symbol color. for example the chartbook that I've attached has green color for the main chart symbol. When I added the 2nd symbol through the Add Additional Symbol study I can't change the color of the line under Subgraphs tab. Am I missing something? |
Chartbook2.Cht - Attached On 2019-01-17 22:59:07 UTC - Size: 30.3 KB - 430 views Attachment Deleted. |
[2019-01-18 16:29:02] |
John - SC Support - Posts: 37448 |
You need to deselect the option for Use Chart Graphics Settings for Subgraph Colors at the top of the Subgraphs page, then you can change the color of the Line On Close by changing the color for the Last subgraph. Refer to the following: Chart Studies: Subgraphs Tab >> Use Chart Graphics Settings for Subgraph Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-22 01:41:37] |
Tariq - Posts: 16 |
Thanks for your help. I have another issue with the same chart. I am not able to see the charts in the Difference (Single Line) study to draw the difference between the symbols added through Add Additional Symbol study. Not sure what I am doing wrong again.
Chartbook2.Cht - Attached On 2019-01-22 01:41:22 UTC - Size: 95.44 KB - 280 views |
[2019-01-22 16:21:53] |
The Difference (Single Line) study does not support the Add Additional Symbol study. Therefore, what you need to do is use the Difference (Bar) study and do the same thing you did for the Add Additional Symbol study in which you change the Graph Draw Type to Line on Close.
[2019-01-22 20:50:59] |
You can also use the Study Subgraphs Difference study: Study Subgraphs Subtract/Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
