Date/Time: Thu, 25 Apr 2024 10:09:39 +0000
High/low of the of the day DOM-chart
View Count: 834
[2019-01-17 20:25:31] |
SBTrader82 - Posts: 7 |
I used custumized DOM-chart with a blue line indicating the HIgh/Low of the day. However this line indicated the high/low taking into account both the day and the evening session. So if the "pit session" high is 2400 and the evening session is 2460, in the DOM I see a blue line at 2460. I would like the high of the day to be considered the high of the "pit session" only. I tried to exclude the evening session, by unlabeling the option "include evening session" in chart properties, but nothing happens. Is it possible to solve this? |
[2019-01-21 05:06:12] |
For this you would need to use the High/Low for Time Period - Extended study: High/Low for Time Period - Extended But the lines are not going to show on the price column in this case but to the left of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
