Date/Time: Fri, 24 Jan 2025 09:52:32 +0000
/ in front of symbol for data file that don't exist
View Count: 649
[2019-01-17 18:37:54] |
Stephan908 - Posts: 46 |
Hi, I trade equities so I go through a lot of symbols each day. Is there an option to auto append a / in front when I type in a symbol that don't have a data file? Thanks!
[2019-01-17 19:11:21] |
We think an easier thing to do is to use the Associated Watch List and add all of the symbols there: Changing the Symbol of a Chart: Using the Associated Watch List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
