Date/Time: Mon, 28 Sep 2026 03:15:07 +0000
[User Discussion] - SC data feed
View Count: 2311
| [2013-11-11 15:26:17] |
| M5amhan - Posts: 468 |
could you help me understand if there are any benefits from switching over from my infinity data feed to paying SC for a package and data? specifically relating to the data, is there any real noticeable differences between the two? would the 1min ES chart look like this? http://www.sierrachart.com/image.php?l=138418370559.png thanks Date Time Of Last Edit: 2013-11-11 15:29:46
| [2013-11-12 02:41:16] |
We can only refer you to the documentation for it here: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-11-13 10:14:50] |
| User33681 - Posts: 37 |
Yes, the SC new datafeed is streaming. When I compared TOS vs SC vs Transact, TOS and SC candles are forming exactly the same and the tick countdown is in synch. Transact creates fewer candles for the same time period/type (tick/min). One can still use Infinity as their broker. |
| [2013-11-13 15:06:12] |
i am aware it is real time would you mind showing me a 500 tick chart and a 1 min chart both of ES from your most recent data? on the SC data feed Date Time Of Last Edit: 2013-11-13 15:07:13
| [2013-11-13 15:44:06] |
here you go - 11-13-13 - 10:42 a.m. - tried to capture similar timeframes on both charts |
| [2013-11-13 15:46:01] |
use Edit > Screen Images > Upload Chart
| [2013-11-13 16:09:23] |
SC charts for CL for comparison to TOS who wish to see CL - 233 tick - 1 min - 10 min
| [2013-11-13 16:10:59] |
here is the sshot
| [2013-11-13 16:12:14] |
it isnt working.. you need to use Edit > Screen Images > Upload Chart
| [2013-11-13 16:18:03] |
ok did that - let's see if not include your email address |
| [2013-11-13 16:19:48] |
CL - let's try this again
| [2013-11-13 16:20:12] |
I will create a new post.
