Date/Time: Fri, 24 Jan 2025 09:35:42 +0000
SIM order fills in replay mode
View Count: 810
[2019-01-17 10:55:48] |
User354816 - Posts: 21 |
For my reviews i´d like do display my SIM Order fills in replay mode. Don´t no how to do this if its possible ? Thank you ! |
[2019-01-17 17:45:28] |
The display of Order Fills is the same regardless of whether they are from Simulation Mode or not. Refer to the following for turning on the display of Order Fills: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-17 18:32:33] |
sorry, maybe my discription was missunderstanding. I want to display trades that i have already done in SIM in the past. So when I do the replay the trades that I have done pop up just at that time. Because I want to review the trades with all the parameters ( Volumeprofile etc.)as they where live at that time. Hope you understand me ?! Thank you ! |
[2019-01-17 19:13:40] |
This is not supported.
