Date/Time: Fri, 24 Jan 2025 09:39:37 +0000
Manage Chart Drawings Window
View Count: 898
[2019-01-17 08:15:50]
User907968 - Posts: 825
Hi Support,
Please consider adding a 'Select All' button or menu option to the new 'Manage Chart Drawings Window'.
This would be very useful for bulk adjusting drawings when rolling futures contracts.
Thanks.
[2019-01-17 08:41:46]
You can effectively do this by enabling the Multiple Selection option, select the first item in the list, scroll to the last item in the list, hold the Shift key and select the last item.
[2019-01-17 09:15:32]
Ah ok, I didn't think to try that.
I was trying to drag the multiple selection using the mouse, doh.
Thanks for the help.
