Date/Time: Fri, 24 Jan 2025 09:33:08 +0000
Risk/Reward Tool Incorrect Values
View Count: 1423
[2019-01-17 07:46:47] |
User371906 - Posts: 141 |
Hello, I am getting a higher amount with my Risk/Reward tool after upgrading to new version, checked the SC web site and checked settings as specified but continue to have this issue which was working correctly before. Also in a higher time frame the same plotted R/R Tool will give a reading twice as high as the lower time frame in Stop and Profit. Version 1862 / Set to Dollar / NQH19 / NY Time Chart Settings: Price Display Format .01 / Tick Size 0.25 Renko 10-6-0: http://www.sierrachart.com/image.php?Image=1547710766859.png Renko 18-9-0: http://www.sierrachart.com/image.php?Image=1547710805275.png Thank you g Date Time Of Last Edit: 2019-01-17 07:47:47
[2019-01-17 18:39:31] |
You need to set the Trade window order quantity to be the same on both of those charts: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-17 18:39:51] |
When displaying the Currency Value for the Reward/Risk tool, it takes into account the currently selected Quantity. You had a quantity of 4 in one image and a quantity of 8 in another, which explains the 2 fold increase. This is explained in the equation for the currency in the Show Currency section found here: Chart Drawing Tools: Reward/Risk Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-17 18:57:22] |
Your absolutely correct, Thank you for your time to reply. Kudos g |
