Date/Time: Fri, 24 Jan 2025 09:52:01 +0000
[Programming Help] - Quote Board
View Count: 686
[2019-01-17 02:50:44]
User731023 - Posts: 138
Is there a way to have the QuoteBord change at/when it opens for
overnight session. (5:00 CST)
Thank you as always,
image1mmm.jpg / V - Attached On 2019-01-17 02:49:46 UTC - Size: 35.96 KB - 266 views
[2019-01-17 18:30:49]
If you are referring to the daily values being reset, then you will need to use the Sierra Chart exchange data feed for proper support for this. Refer to:
Sierra Chart Exchange Data Feed
