Date/Time: Fri, 24 Jan 2025 09:31:43 +0000
Number Bars - Background coloring
View Count: 787
[2019-01-16 22:56:47] |
User336946 - Posts: 37 |
When using Numbers Bars and setting the "Use Separate Colors for Text Coloring Method" option, it forces the background coloring to use the custom text colors. I'd like to be able to have my background colored one way and the text another. In addition, it would be nice to be able to have those who meet the percentage threshold bolded along with being able to be colored differently. |
[2019-01-17 01:11:00] |
, it forces the background coloring to use the custom text colors. I'd like to be able to have my background colored one way and the text another. This is not correct. We do not know how you come to this conclusion like this. This is not what this setting does it all. It functions as documented:Numbers Bars: Input Settings for Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-17 01:11:12
[2019-01-17 01:43:24] |
Well, it doesn't work as you say it does.. unless I'm doing something wrong. See attached video. Also attached chartbook. Date Time Of Last Edit: 2019-01-17 01:45:17
Private File nbars.Cht - Attached On 2019-01-17 01:45:08 UTC - Size: 30.35 KB - 480 views |
[2019-01-17 15:45:48] |
John - SC Support - Posts: 37448 |
We found the problem and have fixed it. The one Background Coloring option of Based on Dominant AskVol BidVol to Volume at Price Percentage was incorrectly using the text colors. This fix will be in the next pre-release (v 1863). When available you can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
