Date/Time: Fri, 24 Jan 2025 10:03:44 +0000
Write Bar and Study Data To File Study - how to add symbol and bar period
View Count: 778
[2019-01-16 18:31:19] |
User719310 - Posts: 23 |
Hi, I am using the "Write Bar and Study Data To File Study" to write the study data to a text file, but it does not add the Symbol and Bar Period to the text file. Eg: EU6H19 0.00050 Range How can I do this - get the Symbol and Bar Period? I know that I can get this info in the title of the text file, but I require it in the body of the text file as I am doing this for multiple symbols and bar periods. Regards James |
[2019-01-16 19:28:23] |
You will have to just make your own custom study to accomplish this.
[2019-01-16 19:51:17] |
I'm new to this environment. Can you give an example of a study, function or variable where the Symbol and Bar Period data is captured? |
[2019-01-17 18:35:00] |
For the symbol, use: ACSIL Interface Members - Variables and Arrays: sc.Symbol For the bar period, use: sc.GetBarPeriodParameters() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-17 18:35:12
