Date/Time: Fri, 24 Jan 2025 08:40:44 +0000
[User Discussion] - 'Study Price overlay' and 'Period OHLC Variable Period'
View Count: 993
[2019-01-16 09:49:16] |
samual sprat - Posts: 343 |
Hi, I'm using the study 'Period OHLC Variable Period' on a 30m chart and overlaying it onto a 500 volume bar chart using Study/Price Overlay. There are a couple of problems. First one is that when a new bar loads, the forward projection on the source chart (30m) reverts to zero bars projection. Second issue is that when I use Study/Price Overlay to replicate the 'Period OHLC Variable Period' to the 500 volume bar chart the lines are not projected to begin with. So to replicate. If I set 'Forward project OHLC Lines' to 'Yes' and 'Number of Forward Bars to Project' to '10' on the 30m chart for example, when it's replicated to the 500 volume bar chart the forward projection isn't there even if it is on the 30m chart Thanks S Date Time Of Last Edit: 2019-01-16 10:35:27
