Date/Time: Fri, 24 Jan 2025 09:42:31 +0000
drawing Gann angles
View Count: 1578
[2019-01-16 06:33:33]
User28682 - Posts: 233
Is there a SC study that draws Gann type angles?? 1x2, 1x1, 2x1 etc.
Date Time Of Last Edit: 2019-01-16 06:33:55
[2019-01-16 18:59:46]
There is a Drawing Tool that will draw Gann angles. It is called the Gann Fan. Refer to the following:
Chart Drawing Tools: Gann Fan
[2019-01-16 19:10:25]
Thanks, when you use the tool, how do you line up the 45 degree angle so its in the right spot? When I use that tool and click on a starting point, it draws the angles but they can be anywhere?
[2019-01-17 18:44:57]
The first point you click at will be the starting point and then the configured lines for the Gann Fan will be drawn out from that point and ending at the bar where the second point is placed, and extending out from there.
Date Time Of Last Edit: 2019-01-17 18:46:51
