Date/Time: Fri, 24 Jan 2025 14:32:33 +0000
Orders on Charts
View Count: 1220
[2019-01-15 23:44:03]
User94606 - Posts: 327
Is there a way to show the P/L on the chart once the order has been closed? I enabled the "Show Order Fills" under Trade but this only shows the entries/exits. It does not show P/L
[2019-01-16 02:52:08]
Yes. There is a setting for this and is explained here:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
But be sure to also read this section:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
[2019-01-16 18:49:45]
One additional question: How do I change the color of the markers on the attached chart (see red arrow)?
imageMarkers.jpg / V - Attached On 2019-01-16 18:49:25 UTC - Size: 70.33 KB - 325 views
[2019-01-16 19:23:52]
This is explained here:
[2019-01-23 15:56:43]
What is the field name to change the color on the markers (arrows) - see attachment? I looked at the reference I was provided but cannot find the field name to change
imageArrows.jpg / V - Attached On 2019-01-23 15:56:31 UTC - Size: 9.99 KB - 261 views
[2019-01-23 19:22:22]
Please ignore my last question regarding the setting/configuration for the markers. I managed to find the answer.
The only question I have now, where settings control the actual size of the markers (see blue arrow on attachment)?
imageMarker Size and Position.jpg / V - Attached On 2019-01-23 19:21:30 UTC - Size: 55.3 KB - 300 views
[2019-01-24 19:34:41]
IS IT POSSIBLE TO PLACE A BUY STOP ORDER (WITH SL+TP) DIRETCLY IN CHART WINDOWS AND DRAG & DROP it ?wHERE i COULD FIND THIS INFO PLEASE.
Yes. Refer to Chart Trading:
Chart Trading and the Chart DOM: Entering Orders From the Chart
Refer to Fill Marker Size:
Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
Date Time Of Last Edit: 2019-01-24 19:34:54
