Date/Time: Fri, 24 Jan 2025 08:31:21 +0000
Change Font Size of Volume Numbers
View Count: 1656
[2019-01-15 09:04:09] |
User541156 - Posts: 67 |
Is it possible to change the font size of Volume Numbers displayed on chart?
Untitled.png / V - Attached On 2019-01-15 09:04:00 UTC - Size: 41.82 KB - 372 views |
[2019-01-15 19:42:10] |
The Volume numbers are controlled through the main Chart Text Font. Refer to the following: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
