Date/Time: Sun, 20 Sep 2026 17:44:37 +0000
[User Discussion] - Help with Data Spikes
View Count: 825
[2019-01-15 06:11:07]
rwilliams1 - Posts: 347
Everyday I have data spikes between session open and closes that distort my charts rendering them completely unreadable. I have manually tried to fix the problem by changing the session start/stop times, but for whatever reason the spikes still occur. Then I have to go through each individual chart and drill down to a lower time frame to try and find the exact bar to delete. This is extremely tedious, especially when I have to do it everyday on multiple symbols.
Do you have any suggestions on how to remove data spikes quicker? Or would it be too much trouble to add the option to delete the individual bar simply by right clicking on the bar and adding an option to delete that specific bar? At the moment, using the data editor is like searching for a needle in a haystack and very cumbersome. And the problem is compounded when using the Custom Symbol features.
[2019-01-15 06:57:56]
Update: I'm now noticing that not only do these spikes occur during session open/close but they also occur anytime I close and restart the program.
