Date/Time: Fri, 24 Jan 2025 08:41:28 +0000
OCO and Bitmex
View Count: 1509
[2019-01-14 22:30:50]
User661434 - Posts: 27
Since some time Bitmex doesn't allow OCO orders anymore.
Is there a possibility to use OCO orders,and to keep them inside Sierra, and send them to Bitmex as regular orders when hit?
Thanks for helping me with this issue
[2019-01-14 23:38:48]
We did not know that. You can disable the use of those. Refer to:
Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General)
And you also will want to disable the option to use server-side bracket orders.
Date Time Of Last Edit: 2019-01-14 23:39:15
[2019-01-15 11:11:24]
Thanks You for your answer:
They have halted this service 10th November 2018, here is the newslink for that
https://blog.bitmex.com/api_announcement/
[2019-01-15 19:32:13]
Okay thank you for the link.
