Date/Time: Fri, 24 Jan 2025 08:38:18 +0000
bug: maximized windows automatically restoring
View Count: 643
[2019-01-14 22:08:40] |
User814219 - Posts: 38 |
This has been bugging me to no end I thought I'd bring it up. I have 12 charts on a 3x4 array so I often 'maximize' a chart to view it fullscreen and then 'restore' it afterwards. When I 'maximize' a chart for the first time, a split second later, it will 'restore' the chart on its own. Then I have to 'maximize' the chart again and after the second time, the chart stays 'maximized' like it's supposed to until I 'restore' it. Then when I select a different chart and 'maximize' it for the first time, a split second later, it will 'restore' the chart on its own again. Then when I 'maximize' it again, it stays maximized like it should. Originally, I had hotkeys set up for 'maximize' and 'restore' so I thought maybe there was a bug with hotkeys. So I deleted the keyboard shortcuts and maximized manually but it still occurs. What's even more frustrating is this doesn't happen every single time. So when you guys are testing this, you might not be able to reproduce this instantly. But it's definitely there. |
[2019-01-14 23:09:43] |
There is no way we would be able to reproduce this. It is going to be caused by the operating system. Unless it is related to you doing something like hiding the title bars on a chart. We recommend not to hide the title bars if you are doing that.
