Date/Time: Wed, 12 Feb 2025 21:05:50 +0000
Number Bar Calculated - High-Low Range in Pullback
View Count: 1362
[2019-01-14 19:42:45]
lpfin123 - Posts: 59
Good afternoon,
I use the Number bar Pullback and the Number bar calculated values associated with it.
For some reason, in the "number bar calculated values", I don't get a value for the "High-Low Range" on the pullback column (but I do on the previous candles).
Is there a way that I can get it or can it be added?
See attached picture for blank "High-Low Range" in Pullback column,
Thank you,
image19-01-14, Mon, 14-40-11.JPG / V - Attached On 2019-01-14 19:41:49 UTC - Size: 132.61 KB - 403 views
[2019-01-14 22:31:07]
The Pullback Column is not a standard bar and Sierra Chart does not keep track of the specific High and Low for it. This is why the data for the High-Low Range is not available in the Pullback column.
[2020-11-15 20:38:44]
j4ytr4der_ - Posts: 946
Would it be possible to add support for accessing the high/low of the PB Bar? This is extremely useful information that seems to be impossible to access (at least without using ACSIL) which is a shame.
[2020-11-17 10:14:29]
Ackin - Posts: 1865
j4ytr4der_)
I created it... Check new update:
study: Numbers Bars: Pullback H/L
