Date/Time: Fri, 24 Jan 2025 08:19:35 +0000
Trading DOM - Colors, Settings
View Count: 930
[2019-01-14 12:45:21] |
NRGTrader - Posts: 351 |
Is there a method to save all trading DOM settings for a particular symbol or chart as a DEFAULT or "study", open a different chart/symbol and apply that DEFAULT or "study" to a trading DOM for the different chart/symbol?
[2019-01-14 18:49:04] |
Yes. Refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-14 19:05:13] |
Simple - I neglected to consider trading DOM as "chart". Thanks. |
