Date/Time: Fri, 24 Jan 2025 08:36:20 +0000
Trade Activity Log
View Count: 786
[2019-01-14 11:03:35] |
007700 - Posts: 43 |
In The Trade Activity Log When I drag hold left mouse over 3-4 Rows the color is gray/black is there an option to change it to yellow....? I have tried the graphics settings Chart - Secondary Grid (Colors/Width) Fonts -(Spreadsheet) Also is there an option to color the columns (background) |
[2019-01-14 18:32:13] |
Make sure you are running the latest version of Sierra Chart: Software Download: Fast Update The color setting you want is Global Settings >> Graphics Settings >> Colors and Widths >> General Text Window Highlight Color. There is also a color setting for the background as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-14 18:33:25
[2019-01-14 19:36:32] |
I see window background (whole page) it appears the P&L column is "J" in an excel spreadsheet is there an option to color only selected "columns" (background) spreadsheet supports this under format cells (background color) "Fills" For example: Columns "G" = blue Columns "F" = purple Columns "K" = red Date Time Of Last Edit: 2019-01-14 19:50:16
