Date/Time: Fri, 24 Jan 2025 08:27:09 +0000
[Programming Help] - Documentation on Compiling 64 bit custom studies
View Count: 3024
[2019-01-14 07:02:58]
Dryheat31 - Posts: 13
I checked here: Developing Custom Studies and Systems for Sierra Chart
and here: https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php
But I have not found documentation showing how we can create and compile custom studies to be used with the 64 bit version of Sierra Chart. Please point me in the right direction.
I tried to compile some existing source code and the compiler complained about several SC elements that were not available. So I suspect I will also have to make changes to my source code in order to complete this goal.
Thanks!
[2019-01-14 07:52:51]
User502006 - Posts: 6
Do you have a list of those "elements" you mention ? I ran into a couple myself and know what I did to circumvent the problem ...
(read : it may be the same issue)
Notice, however, that I just *did* compile for 64bits and I saw no difference for 32bits.
Peter
[2019-01-14 18:59:05]
The easiest thing to do is to use the Build >> Remote Build command in Analysis >> Build Custom Studies DLL.
Date Time Of Last Edit: 2019-01-14 18:59:38
[2019-01-15 16:33:54]
Here is the output I get when I perform: Build >> Remote Build command in Analysis >> Build Custom Studies DLL.
-- Starting remote build of Custom Studies Source files: CustomStudy.cpp. 64-bit -- 09:27:42
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
CustomStudy.cpp: In function 'void scsf_CustomStudy(SCStudyInterfaceRef)':
CustomStudy.cpp:275:23: error: 'struct s_sc' has no member named 'PersistVars'
int& logCounter = sc.PersistVars->Integers[0];
CustomStudy.cpp:399:15: error: exception handling disabled, use -fexceptions to enable
catch (char *ErrMsg) {
CustomStudy.cpp:400:22: error: 'ErrMsg' was not declared in this scope
sc.AddMessageToLog(ErrMsg, 1);
CustomStudy.cpp:601:22: error: 'ErrMsg' was not declared in this scope
CustomStudy.cpp: In function 'void fillSubgraph(SCStudyInterfaceRef, SCSubgraphRef, float, float, int, int)':
CustomStudy.cpp:809:76: error: '_RPT1' was not declared in this scope
_RPT1(0, "Custom Line Index: %d Value: %f\n", indexA, customLine[indexA]);
-- End of Build -- 09:27:45
