Date/Time: Fri, 24 Jan 2025 06:55:34 +0000
OpenChartOrGetChartReference Example
View Count: 650
[2019-01-12 17:44:36]
LenderDevTest - Posts: 15
The study "OpenChartOrGetChartReference Example" from the file studies.cpp does not work.
The problem is on the line #6500: "sc.AutoLoop = 0;//Manual looping"
The study was designed for automatic looping. (the study use "sc.Index")
Fix: set "sc.AutoLoop" = 1
[2019-01-12 20:53:56]
The example does work but there was one line of code using sc.Index doing something which was not part of the main example and we added a for loop there.
