Date/Time: Fri, 24 Jan 2025 06:46:10 +0000
Two Charts Sync
View Count: 773
[2019-01-11 17:58:39] |
User551971 - Posts: 34 |
Hi, ist it possible to sync two Charts together. If i draw a Retangle in my 5Min Chart i want see them automaticly in my 1M Chart |
[2019-01-11 19:01:39] |
Yes. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
