Date/Time: Fri, 24 Jan 2025 06:54:06 +0000
Session Times / Dilemma / Dif. Candle Formation
View Count: 1061
[2019-01-11 10:29:47] |
User371906 - Posts: 141 |
Hello, I have a dilemma which I cannot figure out, I trade RTY & NQ futures via CQG data feed both Globex and NYC open/close. In Chart Settings / Session Times I can’t understand which is the setting that is more appropriate to select as one setting will place different candle formation than the other. The formation gives in one setting an idea to trade short and in the other to go long (ex. One has a breaking candle and the other doesn’t, etc) Option 1: Start Time 09:30:00 to 16:14:59 - End Time 16:15:00 to 09:29:59 Evening Start 16:15:00 to 09:29:59 Use Evening Session (Checked) Option 2: Start Time 00:00:00 to End Time 23:59:59 Use Evening Session (Unchecked) Any advice please? Thank You Regards g |
[2019-01-11 22:08:31] |
This is what you normally should be using: Start Time 09:30:00 - End Time 16:14:59 Evening Start 16:15:00 to 09:29:59 Use Evening Session (Checked) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
